MAFT ????? did research no help, quick ????
srGS-t
51
Jul 12, 2005
Hueytown, Alabama
ok I have a MAS translator and I just need to know one thing and I did research it. On the dails that say Base and Aux it says to put Base on C and the Aux on 4 for 550 cc injectors. so dose that mean click the Base 3 time and in saying A, B, C, and then clicking the Aux 4 times? Thanks
Your base knob for the translator using stock injectos 450cc is set at 2. This is how my set up is for now. And everything else i have is at zero. Hope this helps.
aux is used to tune fuel delivery when the aux trigger wire is energized. the aux setting is ADDED TO the WOT setting.. get it?
if you want to run nitrous and you need more fuel, you energize AUX when you spray and you get more fuel then you normally would..
the base dial is to adjust for fuel injector size to 'rescale' i guess.. dial 0 is 450cc injectors, if you want to run 550cc's you want to turn it to 4 which is -20%. (so turn it clockwise 4 clicks).
This is how my MAFT works, goodluck.
    • george bromwell
    • pma1123
    • Sdcryan1
