MAFT blow through setup on my 2g
gst fat
284
Jun 22, 2007
Miami, Florida
So my maft blow through setup is on it's way here, what are the ups and downs? And also I'm running an safc II, any suggestions, I'm running 660cc injectors
I wanna hear personally from people what they think about it and if they ever bad any issues as well
Just run stock, and keep ## bov recirculated. Sell the maft set up. Why do u want the maft setup?
Wow what a waste of info. I have ran a maft gen 1 and a safc for over a year on 1200cc injectors and e85. Car ran great.
Just set the MAF-t to all stock settings. Change only the maf-t's base knob to setup for the 650's. Then use the SAFC to fine tune the WOT.
Maft set up does work well and seems to help a little with spool up(less restriction), some other pluses is that it gives you many different intake/filter options. I have custom intake pipe that pulls air right off the ground. bov placement doesn't matter anymore (pre-gm mass) as well venting it doesn't cause any trouble. Only real con that i have noticed is that they are very sensitive to moisture! heavy rain driving or big puddles can throw off your A/F (being over rich) until things dry out again.
I think you get that problem because from the sound of it you have a custom cold air intake,
And to this guy, I don't think you know what your talking about, no offense and thanks to everyones input
Your right, but this is not a car i intentionally drive out in the rain/poor weather, however just like on a bike it can get you by suprise.
I also havn't experenced any ill effects from cooler weather with the maft.
Cool guys well thanks for the weather report LOL, I live I. Miami and the weather is pretty steady, but it does rain a whole lot
