maf translator ? 1g awd
EXTREMEPT
63
Dec 9, 2004
PENSACOLA, Florida
installed the maf translator and 3" gm maf tapped all correct wires and sodered them....but tge green light is flashing which means loss of rpm signal...i check the connection to the tps to where it gets the signal from,connection is still sodered fine....any suggestions ? this is on a 91 talon awd ....thanks
If the translator is mounted in the engine bay the white wire must be tapped at the CAS pin 2 (black wire). If the translator is mounted inside the car you must tap into pin 109 of the ecu, ignition pulse detect (tach) to get a rpm signal.
these directions i have must be a misprint....the tach signal says pin 4...not pin 2 thanks this should be the fix to the problem i will try to so this in the morning and post again to make sure thats what the problem was...thanks alot reese92tsi !!!!
