MAF/MAS problem on a 2G
Venom55
142
May 3, 2003
Hi guys
I've recently purschased a 95 GST with a 6 bolt swap. I Made the wiring for the CAS correctly using the Raod Race writing. No the car start fine but run way to rich , its puffing black smoke and idling like it has 280 crower cam , but has stockish ones in....
Car had an SAFC 2, but it was unpluged and some wire were spliced in , checked them all and they were fine. Afterward I tought it was the MAS....and i was right. The car idle/run bad even if the MAS is plugged in or not. Tried another one known to be working and same thing.
What can be the problem ? ECU to MAS plug connection? I know its MAS realted since when i unplug some vacuum (more air sucked in engine) the car idle better and as soon as i plugged them back in idle goes down again.
Im ready to qui on this, been 3 days trying to figure this out. What can it really be?
thanks
The SAFC has a wires that requires cutting the mass signal wire. you have to connect both the wires together when you remove the SAFC.
Try unplugging one injector, one by one - to see what injector is causing it to run like crap.
Also snap a pic of the injectors or get the serial number/color from them.
The SAFC has to be plugged in and wired correctly, otherwise it'll run like poo.
