MAF Hack Causing Idle Problem?
thefallen924
Mar 23, 2005
buffalo, New York
ok, i decided to start tryin the free mods on my 1990 gst. i did the Maf hack and drove around, everything seemed to be ok. however, now at random times my car will just idle weird and stall. at first i thought something might be loose so i made sure everything was tight, but im still gettin the same problem. i've also noticed that i dont get the full 11-12 pounds of boost i used to get prior to the mod. again, i thought there was somethin loose but i double checked and everything seems to be tight. anyone have any ideas?
removing the lower honeycomb sometimes causes this. as for lower boost levels... You do have a real boos gauge dont you? Nothe stock joke of a gauge? Im not sure exactly why that is happening. did you remove the restrictor? (Did you add a restrictor?? :coy: )
Good luck and let us know what you find.
:laser:
