Machine shop in Europe
CDgr97GSX
162
10
Feb 11, 2009
Romania, Europe
Hi guys. I'm working on rebuilding my engine and I need a machine shop with some experience in 4g63 engine anywhere in Europe. If anyone knows something it will be much appreciated!
The 4g63 isn't really anything "special" as far as motors and the machining that needs done. A shop that can bore, deck and do a valve job is probably what you are needing, but I am sorry that I am in the US and don't know what kind of shops to expect or look for in Europe.
Thanks you all for answering. There is no problem to ship the block and head. I don't have any good option in my country. First no shop have been working on 4g63 but that is not an issue, the problem is no one have a torque plate and also if i install main APR bolts I have to hone the mains and again no shop will do it. May i get some contact info, please? Thanks a lot
One more question. Maybe i get an answer. I found a machine shop in Romania where i can machine my block and my head. They don't have a torque plate but maybe i can fix that. Do i have to balance all internals? I put everything on a scale and one rod is 2 grams less then other 3. Pistons with rings, locks and pins are same weight all of them so no matter how do i mix them i get one piston+rod and bearings with 2 grams less. then others.
