Lucas oil - dumb question
Status
Not open for further replies.
allgripnoslip
307
3
Nov 6, 2003
Livonia, Michigan
okay dumb question, when adding lucas oil stabilizer (1qt.) do I put in all 4.5 qts. of motor oil THEN add the 1qt. of lucas oil, or do I add 3.5 qts. or oil and add the lucas oil as the last 1qt. thanks!
Lucas is supposed to be a replacement for 1qt of oil.
so . . . . put in 3.5quarts of 10-30 and 1quart of lucas.
It doesn't have to be perfect, but just put in the lucas first, and then fill with oil until you are at the correct level.
EDIT : REMEMBER, too much oil is just as bad as too little :thumb:
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
