lower timing belt cover
Yes, support the engine from below with a jack (use a wood block to distribute the weight so you don't dent the oil pan), remove the motor mount, power steering belt, alternator belt, a/c belt, accessory pully wheels and the harmonic dampener. At that point you should be able to remove the lower timing cover. Be *SURE* you remove all the bolts for the timing cover. There are plenty of them and some are hard to find. Also, keep track of where they came from b/c there are different length bolts.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
