Lower fuel filter fitting!?!?!?
heefro757
Feb 6, 2009
plano, Texas
as i was doing the tune up on my 92 gsx i came across a problem the lower fuel filter line and more importantly the fitting that screws into the fuel filter. it seems that the previous owner had already busted the fuel line because it was in two pieces and had a 3in rubber hose connecting the two medal fuel lines. i have been to all local shops including machine shops and have not been able to locate the right size fitting that will screw into the bottom of my fuel filter. i have even looked for anything that i could screw into it and attach a rubber hose to and grind down the top of it so i can get good contact.
any help will be appreciated.
Im almost positive its a M14x1.5 pitch.
What you need is a compression fitting to convert the fuel line to -AN. Only problem is youll need to buy a -6an fuel line feed kit and a -6an filter.
Actually i found this.
You need this.
Summit Racing ? High Performance Car and Truck Parts l Edelbrock, ACCEL, Moroso, K&N, MSD, Holley & More!
And this.
Earl s Performance 165106ERL - Earl's Performance AN to Tube Adapter Fittings - Overview - SummitRacing.com
That will work so you can use your stock fuel filter.
Hope that helps.
