Lower Control Arm Stud Keep Spinning with Nut!
jm1080
640
3
Jun 13, 2006
Boca, Florida
Well been struggling with this whole tranny job. Basically almost done and was going to replace my lower control arm since I'm down there..I have done this 5 times and for some reason this time I'm struggling...
The ball joint stud keeps spinning with the nut! I already jacked the ball joint part up and nothing..Dropped all the weight of car on the jack positioned under the ball joing and nothing...Hammered it nothing..It didn't even tighten that much, didn't pass the nylon on the locknut yet either..Anyone have any tips or other ways?!?! So pissed at this!! :banghead:
Figured it out on ecmlink forums, you put a wooden block on upper control arm then jack it up so it can put force down onto ball joint! I'm happy again :)
Hope this helps others
Glad you figured it out! That's good info, if the spring pressure isn't enough, just use some scrap materials to block the movement of the arm. I dig it.
