lower control arm help
shotgun94
Sep 24, 2009
Cochrane, AB, Canada
I had a run in with a curb on my 2g talon tsi awd a couple of weeks ago and have been gradually replacing my rear end parts on the right side of my car. I have replaced many parts but the last one i need to swap out is my lower control arm, the one that attaches to the sway bar. I have everything but the bolt in the back out that holds it in, the bolt to the sway bar and hub are out though. I cannot get the bolt in the back out, i have the nut off but the bolt is hitting against the gas tank and wont pull far enough out for me to remove the arm. Im thinking of dropping the subframe about an inch to see if that gives me enough play to remove the bolt or even the arm, it doesent need much to get it out. Any suggestions would be greatly appreciated.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
