Matrixhunter
- 205
- 3
- Sep 17, 2005
Toronto,
So here is the problem-- 6 bolt 1992 TSI FWD
My fuel trims need some help the low trim is at 139% but the other two are at 100%??
The problem that i seem to be having is that the car cannot boost past 11psi and it looks like it fluctuates a bit from 10-11psi back and forth once it reaches this boost level.
I double checked all my connections and there should be no boost leaks.
However the only thing i can think of is either the wastegate arm is not working correcty or there is some sort of boost leak that is stopping me at 11psi. I will do a proper boost leak test tommorow but I just though i'd get some opinions on this.
Also I'm assuming that the low fuel trim would have something to do with the leak if there is one?? Engine is the car is a new jdm with cylone intake and i have a highly ported 14b.
Thanks
Thanks
