2G loss of power @ 6k RPM
SmgHunter
71
May 15, 2014
St.Charles, Missouri
Finally got my talon running again after the balance shaft belt broke, breaking the cps, bending the trigger plate and jumping the timing a tooth).
I messed with the BOV while the car was down(pulled the piston(?) Out of the bov and inspected it) the bottom oring was cracked and I just put it back together. Im now noticing that as I approach 6k rpm my boost falls from 15 psi to 10psi and the car falls on its face. It is idling fine and pulling 19-20 lbs of vacuum. The car also tends to stall when put into neutral or depressing the clutch.
The trigger plate is still bent and is contacting the CPs a little not sure if that could be why
