1G losing fuel pressure while idling
turbo4banger4g63
5+ Year Contributor
36
Dec 30, 2018
lorain, Ohio
my talon will be idling, or very light driving not out of second gear 20 mph, and it will just slowly start losing fuel pressure, it will get all the way down to 10-20 psi and die. but then will start right back up to around 42 psi. did some searching on here but not search after search. seems like everyone elses issue are slightly different. anyone have any insight on this???
yes i'm going to. does the ecu control the fuel pump voltage do you know??
pump is not losing voltage when fuel pressure drops, I am thinking its my FPR, possibly the pump
tried a different diaphram. no change, im gonna pull the pump cause the pump is over 20 years old. I will check the filter also but it is newer
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
