looking to make 600+ awhp
polen
54
May 13, 2007
springfield, Illinois
As the title says im finally building my car to 600+ awhp and need a little help.
First off im looking at the FP3575 for my turbo. Anyone have any experience with it let me know.
Second im upgrading my injectors to 950.
Cams looking at 264/264 not sure what brand yet. Let me know your opinion Fidanza adjustable cam gears as well.
Biggest question is what pistons and compression ratio should i run? This will still be a street car as well as strip so keep that in mind.
eagle rods, head studs, valves etc.
Let me know guys if there is anything else youd recommend doing. I will be getting a more powerful ACT clutch and replacing my 2600 with it. I got most of the little things covered
I'd recommend making 300awhp before you start even considering 600.
You'll also need to go a LOT further than what you have planned out at the moment. It's really not as easy as you seem to be under the impression that it is.
i already have 300. I didnt just buy a stock gsx and all the sudden want to put 600 horse in it
FP3575 is a really nice turbo...Get the whole FP setup, manifold/Tubular o2 housing, Tial wastegate/BOV etc...
Cams, well, it will depend on your motor setup...Theres cams that will benefit a stroker motor better than a 2.0 high rev...In general, I would say a BC 280 is a good choice...I would run the same cam with a good amount of headwork (valves/springs/retainers/guides/porting)
Then, look into SMIM's, larger Throttlebodies, and large diameter intercooler piping (3")...
Clutch wise, I would run a nice Twin Disc/plate clutch if you have the money, they will take some abuse! Make sure you have a really nice Trans as well for those high rpm shifts!
