Looking for the drivers most facing J-pipe
xxNocturnalxx
698
12
Nov 5, 2011
Tacomptan, Washington
From what I can see there are 3 main different types of J-pipes, correct me if I'm wrong. There's a passenger facing one mainly for SMICs. Then there seems to be more of a mid one that goes between the fans and ends up near the top of the waste-gate actuator? And lastly one that bends even more so to the drivers side that almost ends up in front of the hot-side of the turbo.
Anyways I am trying to find the drivers most facing one because it's going in a Colt and I need to make sure I will have enough space for my half sized radiator. Does anyone know or can link the most drivers facing J-pipes?
Most just point down and you would use a 90* coupler to get it pointing at the drivers side. Look at the vrsf kit and you can see how they get there's to the drivers side. My gvr4's stock j-pipe makes its go over the top and then drop down. Which also keeps it near a lot of heat. I like the vrsf kit cuz it drops your ic pipe low and away from heat.
