Looking at a 90 gst ...just need to know what to look for
talon1987
237
7
May 3, 2004
chicago, Illinois
well its a 1990 gst with 148,000 5 speed tranny .... what specific problems should i be looking for .... such as leaks, tranny slipage or known engine part failers ... what test and question should ask to be performed :dsm:
Ask if timing belt (TB) ever broke (and got bent valves) or if ever had a valve job. How many miles ago was the TB last changed (need to change every 60000) and what other TB parts were replaced (eg. tensioner, pulleys, B belt). Water pump ever changed? Does coolant look normal (not foaming, dirty, oily). Does A/C work? How old is battery? Does exhaust have white or blue smoke? If stock radio, make sure you get the first power on "code". Are tires wearing unevenly? Move the top of tires in/out to check for loose lower/upper ball joints (same side to side for tie rod ball joints). Has car had lower lateral arm replacement recall done? Are headlight lens foggy? Start from stop in 2nd gear to check if clutch slips. Do wheels/steering wheel shake when brakes applied? Any CV joint noise when turning all the way going 1 mph in a circle each way? Everything work? Ever been in an accident? Check for crankwalk on left turns (search forum for how to check). Is the jack/lug wrench and spare still there? Is the gear shift sloppy? Are all the tires in good shape and the same size?
That should keep ya busy and impress him like you know what you're doing
alright cool thanks for the info. it will help alot. im hoping this car is decent enough since its 600$ everything looks decent in the photos, but we all know how that goes. thanks again :)
