Look at my logs please... knock problems.
90 GSX
322
Jun 24, 2004
Fremont, California
I just got a new chip expecting the new timing maps to fix my knock issues but it didn't. My mods are in my profile but the jist of it is, I get a lot of knock. It is most likely because I have 2g pistons and a stock 1g EPROM Ecu. I just got a new chip from dsmchips with 2g timing maps adapted for a 1g, with 10.5:1 a/f ratio, 2g mas, and some other small things. The log I am posting is at a mere 11 psi and my timing is back down to about 2*, maybe 1.5* btdc. The car has no boost leaks, brand new turbo, I mean the car is really clean and well built. It doesn't pull as hard as my friend's oil burner, zip tied bumper talon. I thought I logged more pulls but this one is a pretty good representative. The chip seemed to make the knock a little worse, but at 2* btdc with my 1g mas and stock timing I'd see about 10-12* of timing at WOT, but now I have seen it as low as 3* or 5* with my timing set at 5* btdc. I had the boost set at 15 but I had to back it down because this knock is out of control. Even with the new timing maps and the timing retarded it runs like a dog at 15psi and runs half decent at 11 psi (much faster than at 15). Take a look... The knock is usually worse, and my o2 voltage is usually a little higher and my timing is a little lower. I'll get more logs tomorrow but tell me what you think about this one. Keep in mind in this log my base timing is about 1-2* btdc.
TIMA FTRH O2-R TPS RPM KNCK INJP
40° 99.8% 0.43V 18.8% 3531 0 1.79ms
40° 99.8% 0.74V 19.6% 3531 0 2.05ms
40° 99.8% 0.10V 20.0% 3563 0 2.05ms
40° 99.8% 0.72V 20.4% 3531 0 2.05ms
40° 99.8% 0.39V 21.2% 3563 0 2.30ms
40° 99.8% 0.47V 22.4% 3563 0 2.56ms
40° 99.8% 0.06V 26.3% 3594 0 3.33ms
36° 99.8% 0.78V 30.6% 3625 0 4.10ms
32° 99.8% 0.66V 40.4% 3688 0 5.63ms
27° 99.8% 0.82V 53.3% 3781 0 9.47ms
18° 99.8% 0.86V 69.4% 3906 0 12.80ms
15° 99.8% 0.84V 93.3% 4031 0 12.80ms
15° 99.8% 0.86V 100.0% 4250 0 12.80ms
16° 99.8% 0.84V 100.0% 4438 0 13.31ms
15° 99.8% 0.84V 100.0% 4563 0 13.31ms
16° 99.8% 0.84V 100.0% 4750 0 13.31ms
16° 99.8% 0.84V 100.0% 4781 0 13.31ms
16° 99.8% 0.84V 100.0% 5000 0 13.06ms
17° 99.8% 0.84V 100.0% 5094 0 12.80ms
17° 99.8% 0.84V 100.0% 5188 0 12.80ms
18° 99.8% 0.84V 100.0% 5344 0 12.80ms
19° 99.8% 0.84V 100.0% 5438 0 12.80ms
19° 99.8% 0.84V 100.0% 5594 5 12.80ms
17° 99.8% 0.82V 100.0% 5688 4 12.80ms
17° 99.8% 0.82V 100.0% 5781 3 13.31ms
18° 99.8% 0.82V 100.0% 5844 2 13.06ms
19° 99.8% 0.82V 100.0% 5938 1 12.80ms
20° 99.8% 0.82V 100.0% 6063 1 12.54ms
20° 99.8% 0.82V 100.0% 6094 6 12.54ms
19° 99.8% 0.82V 100.0% 6219 5 12.54ms
19° 99.8% 0.82V 100.0% 6281 4 12.54ms
20° 99.8% 0.82V 100.0% 6375 3 12.54ms
21° 99.8% 0.82V 100.0% 6438 9 12.54ms
18° 99.8% 0.82V 100.0% 6500 10 12.54ms
18° 99.8% 0.82V 100.0% 6563 9 12.29ms
18° 99.8% 0.82V 100.0% 6688 15 12.29ms
16° 99.8% 0.82V 100.0% 6656 15 12.03ms
18° 99.8% 0.90V 9.8% 6344 0 1.54ms
45° 99.8% 0.55V 9.8% 5469 0 1.28ms
45° 99.8% 0.60V 9.8% 4875 0 1.28ms
45° 99.8% 0.72V 9.8% 4906 0 0.00ms
Anybody?
It looks like the o2 voltage drops a bit when the knock kicked in. Is it normal to see 0.80-0.82 at 10.5:1 A/F ratio??? Before the chip I used to see 0.89
I don't know much about the 2gmaf thing in the 1g. What I do know is that it flows 15-25% leaner then the 1g maf. If your timing & a/f are chipped without tha in mind it would explain why you are getting lower 02 values and knock above 5500rpm on pumpgas. Now that you know FTRH and TPS are working correctly get rid of them and add airflow/timing/o2/knock.
Edit: Can you reinstall the 1g maf to test this?
He mentions that the chip compensates for the 2G MAF:
"I just got a new chip from dsmchips with 2g timing maps adapted for a 1g, with 10.5:1 a/f ratio, 2g mas, and some other small things." ;)
Like scottsee mentioned, eliminate FTRH & TPS, add in airflow & also IDC instead of INJP - this way we can see if your RC550's are up to the task or being maxxed out.
I know this is a little late, but I just got back from vacation. I see that your IPW actually drops during the run. Have you tried swapping out the 2g MAS with a know working one. You could have an air metering problem. Leak check???
