Long cranking after injector install
eclipto98
61
Sep 7, 2014
lodi, California
So i installed some 760 precision turbo injectors and put in the values for link but now it takes longer cranking to start is that normal? i have to hold the key on until it bogs up and starts
Do you have a aftermarket fuel pressure gauge to tell you what pressure you are at? Did you reinstall everything correctly?
Jayson
No to the after market fuel guage but yes to the reinstallation. It runs fine under load it's just the initial start up and idle . It idled like it's missing I have bigger cams but it wasn't like the with my stock injectors
Jayson
