Logging With Palm Logger
Chicken Patty
1,446
19
Jun 26, 2007
Miami, Florida
Good day guys,
My buddy let me borrow his logger for a bit so I can use it on my car and get familiar with it. The logger works great and its a big help when tuning. However, it only seems to connect at no more than 3 samples per second. Is this normal? That i know off they are supposed to connect at at least five samples per second. Also, sometimes it'll just loose connection. What can cause this? Has anybody fixed this problem before? COuld the cable be the main suspect here?
Ok its been a while, but if you havent done the byte packet test it could help. I dont even remember how to get to the screen. I just know that you run the byte packet for 2min then stop it,then run the inter packet for 2min.Now go up to the top of the screen, and turn both values up 5 clicks.Then hit ok.It should help. It helped me.As far as it disconnecting i would check the connection on both ends of the cable, and make sure your connection to the palm is good!;)
Ok its been a while, but if you havent done the byte packet test it could help. I dont even remember how to get to the screen. I just know that you run the byte packet for 2min then stop it,then run the inter packet for 2min.Now go up to the top of the screen, and turn bothe values up 5 clicks.Then hit ok.It should help. It helped me.As far as it disconnecting i would check the connection on both ends of the cable, and make sure your connection to the palm is good!;)
cool. I'll give that a shot later tonight and let you know how it went. Thanks man.:thumb:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
