logging question
streetsoldier60
55
Feb 16, 2008
Celina, Ohio
okay so i don't know if this has been asked or not...done a lot of reading on here but still haven't seen what i'm quite looking for. so please don't rip my head off just curious! LOL. so when you are logging with palm n stein...i'm using the rom for laptops but anyways the o2 readings give your your a/f ratio at least upstream one does im aware of that but is that real time like a wideband shows you or no? is it still narrow band? thanks for the help.
on 2gs i log the STFT and LTFT fuel trims you want to keep them as close to zero as possible the 02 voltage should be right around 93 at WOT if i remember correctly its been a while since i used palm and the o2 still reads narrow band if that helps you any
Yes it's still narrow band, unless of course you have a wide band o2 sensor. If by "real time" you mean what is happening when the logger sent the request for the data, then yes. It does log real time A/F ratio's. The thing with the narrow band is that they aren't accurate enough to be worth the time to try and tune with. Your talking about a 1 volt sweep. I do not recommend using the factory, or any other narrow band o2 sensor for tuning. When I tune cars on pump gas and take my WB back out, the factory narrow band usually see's around 0.87 to 0.91 volts on WOT pulls. Again I do not recommend using the narrow band o2 sensor for any tuning.
hey that is exactly what i needed to know. thank you guys much. and yes I will be looking into buying a wideband 02 and guage here in the near future so between the logging the wideband and the safc i should be able to do some decent tuning for the time being..anyways thank you much everyone for the insight! -Dan :thumb:
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
