logger sync cable needed
boostedinthe843
307
Oct 22, 2008
beaufort, South Carolina
i have a treo 90, just downloaded my logging program, and got the serial to usb converter but alas, that was a waste of 50 bucks, damn you staples:notgood:. my question is does any one know where i can get a serial sync cable for a handspring treo 90? thanks, it is a usb cradle type to serial i need by the way
If you have a data logger cable to connect to the car, are you sure you have the right one? The cables for a laptop versus a palm are different. They look the same, but in the serial end the pins are different. IDK about the USB adapter, but I couldn't get my logger cable to sync my ECU to my laptop untill I slipped the "null modem adapter" in between the cable and the computer's serial port. The adapter is $5 at any worthy computer-geek store. Null-modem and serial look the same, they just connect different pin configurations. Good luck.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
