Logger problem...MMCD!
firehawk
169
Oct 17, 2003
Vandergrift, Pennsylvania
well heres my problem. My logger will do all of the tests...(i.e..injector tests) but it wont log anything. I've looked all over here and cant find anyone who had the same problem. Im not getting a serial comm error or anything, just no data. It worked previously, but my logger battery died, i recharged it...loaded the program again and now nothing. Any ideas?
i dont know but make sure you un-check "pause" and check mark the "log" button
The parameters must be highlighted before they can log anything.
See how ERPM and INJP are highlighted. Those will be the only two parameter that will be logged. If you want to log a value, you have to select it so the program knows what to monitor.
What do you mean it's reading 0hz? Is it showing any data at all on the screen like when you just monitor or is it just not logging?
down in the bottom left hand corner it say 0hz. Its not logging anything under monitor...it doesnt work
Try going under the preferance menu and check at what speed it reads at. I just remembered mine did something like this and that was the problem. I selected the default option and it worked after that.Default is 1920 but it's recommended that you run at 1953.
