Log
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
what do you guys think of this log?
RPM Timing O2 1 Bank 1
3391.0, 22.0, 0.94,
3621.0, 20.0, 0.94,
3871.0, 16.0, 0.94,
4125.0, 13.0, 0.96,
4387.0, 11.0, 0.96,
4691.0, 12.0, 0.96,
4969.0, 13.0, 0.96,
5211.0, 13.0, 0.98,
5469.0, 16.0, 0.98,
5723.0, 17.0, 0.98,
5949.0, 19.0, 0.98,
6137.0, 20.0, 0.98,
6324.0, 20.0, 0.98,
6492.0, 22.0, 0.98,
6656.0, 22.0, 0.98,
6813.0, 22.0, 0.98,
6926.0, 23.0, 0.98,
rich and with that timing you're probably tuning at 12-14psi. try upping it to 17-18psi. that dropped my timing down to 19max and made it much easier.
With thouse readings you can probably get away with leaning it out 5% across the rpm Range. Just keep an eye on your timing and your 02 readings can very from car to car. I have mine reading at .94 across the rpm range. If I hit .91, I start seeing some timing (knock) being pulled at least on my setup. Top of my rpm range sees 19 degrees.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
