Log Review Advice
Apeximprt2nr
620
5
Apr 20, 2005
Northern, New Jersey
Hey guys, I just want to see waht you have to say about this log. I'm running 15 psi on a 14b and evo 8 FP and stock injectors for now. SAFC II is hooked up but dialed in at 0% so no tuning is done yet. I'm looking to get advice on what to do. I generally know, but wanna get more info.Rest of the supporting mods are in my profile, but aren't worth mentioning, just typical mods. I know I should have just logged Timing, RPM, and 02, but I just did this on the fly.
Also, my stock clutch was slipping a bit so that may have affected the log and RPM's raising.
*I know I'm knocing between 6.1k- 6.8k but why on only 15psi and EVO 8 FP? 206* coolant temp. had an effect as well.
I have boost leaks that need to be fixed. I should have fixed those first, but just wanted to get some log in for the time being.
Code:
Coolant* RPM Ign. Timing Air temp. Throttle Pos.
203	1880	27	77	13
203	2028	28	77	15
203	2136	22	77	27
203	2376	3	75	90
203	2680	1	73	90
206	3308	0	73	90
206	3624	3	73	90
206	4136	5	73	90
206	4632	6	73	90
206	5160	8	71	90
206	5636	12	71	90
206	6104	16	71	90
206	6496	15	71	90
206	6868	13	71	90
206	6376	36	77	1
203	4932	24	78	1
206	4512	24	78	1
206	4276	23	78	1
206	4040	23	78	1
206	3176	31	77	15
206	3088	23	77	1
206	2932	33	77	15
Thanks. :thumb:
