Log help.. using afc2 660's and 190
MiSFiTz
56
Jan 5, 2004
Chillicothe, Ohio
This is the log i took, its a 3rd gear pull... i ran out of road and let off dunno if this will work?
What should i adjust if anything.. I dunno what this means..
Time,Load,Short Term Fuel Trim 1,Long Term Fuel Trim 1,RPM,Timing,TPS,O2 1 Bank 1,O2 Trim 1 Bank 1,O2 2 Bank 1,O2 Trim 2 Bank 1
00:00.87,44.4,0.0,-12.0,1420.0,13.0,60.51,0.92,0.0,0.94,0.0
00:01.74,44.01,0.0,-12.0,1624.0,15.0,69.55,0.92,0.0,0.92,0.0
00:02.63,44.79,0.0,-12.0,1844.0,16.0,88.8,0.9,0.0,0.88,0.0
00:03.52,47.94,0.0,-12.0,2088.0,17.0,97.45,0.92,0.0,0.9,0.0
00:04.40,50.29,0.0,-12.0,2328.0,19.0,97.45,0.92,0.0,0.9,0.0
00:05.28,55.8,0.0,-12.0,2592.0,17.0,97.05,0.92,0.0,0.9,0.0
00:06.17,64.83,0.0,-12.0,2848.0,13.0,97.05,0.94,0.0,0.92,0.0
00:07.05,78.98,0.0,-12.0,3168.0,8.0,94.3,0.96,0.0,0.94,0.0
00:07.96,80.55,0.0,-12.0,3516.0,8.0,94.3,0.96,0.0,0.94,0.0
00:08.84,82.51,0.0,-12.0,3924.0,9.0,94.3,0.96,0.0,0.94,0.0
00:09.72,83.69,0.0,-12.0,4292.0,10.0,94.3,0.96,0.0,0.96,0.0
00:10.61,84.87,0.0,-12.0,4732.0,9.0,94.3,1.0,0.0,0.98,0.0
00:11.51,84.48,0.0,-12.0,5044.0,13.0,94.3,1.0,0.0,0.98,0.0
00:12.39,51.08,0.0,-12.0,5352.0,15.0,94.7,1.0,0.0,0.98,0.0
00:13.27,21.61,0.0,-12.0,5260.0,35.0,0.0,0.74,0.0,0.62,0.0
00:14.15,16.5,-2.0,-12.0,4792.0,24.0,0.0,0.88,0.0,0.58,0.0
00:15.05,12.18,0.0,-12.0,4276.0,23.0,0.0,0.02,0.0,0.02,0.0
00:15.93,13.36,0.0,-12.0,4072.0,23.0,0.0,0.02,0.0,0.0,0.0
This any better?
Time,Short Term Fuel Trim 1,Long Term Fuel Trim 1,RPM,Timing
00:00.44,-13.0,-12.0,2084.0,21.0
00:00.88,-12.0,-12.0,2140.0,15.0
00:01.31,0.0,-12.0,2224.0,15.0
00:01.77,0.0,-12.0,2312.0,17.0
00:02.21,0.0,-12.0,2416.0,19.0
00:02.66,0.0,-12.0,2524.0,17.0
00:03.09,0.0,-12.0,2648.0,15.0
00:03.54,0.0,-12.0,2780.0,13.0
00:03.99,0.0,-12.0,2908.0,11.0
00:04.42,0.0,-12.0,3060.0,9.0
00:04.86,0.0,-12.0,3208.0,8.0
00:05.32,0.0,-12.0,3368.0,7.0
00:05.77,0.0,-12.0,3572.0,7.0
00:06.21,0.0,-12.0,3768.0,8.0
00:06.65,0.0,-12.0,3948.0,9.0
00:07.09,0.0,-12.0,4136.0,9.0
00:07.55,0.0,-12.0,4340.0,9.0
00:07.98,0.0,-12.0,4536.0,9.0
00:08.43,0.0,-12.0,4692.0,9.0
00:08.86,0.0,-12.0,4896.0,10.0
00:09.31,0.0,-12.0,5052.0,10.0
00:09.76,0.0,-12.0,5228.0,11.0
00:10.21,0.0,-12.0,5368.0,13.0
00:10.65,0.0,-12.0,5548.0,15.0
00:11.10,0.0,-12.0,5696.0,15.0
00:11.55,0.0,-12.0,5860.0,15.0
00:11.98,0.0,-12.0,6008.0,16.0
Do a pull with timing, knock, and rpm. Maybe o2 sensor voltage or tps as well. That is too much to look at.
