Log and SAFC advice, log suggestions
OldSchoolMotors
44
Aug 6, 2007
Cleveland463.com, Ohio
Ran several logs today here are the first and last, as I was making adjustments to the SAFC-II. From the 1st to 4th log looks like I'm getting closer to tuning out the knock? Suggestions, advice, rants, etc... welcome.
Aug.3rd 85degrees
16psi - 94 octane, Fuel Pressure 38psi
SAFC Throttle Points - 1k, 1.6k, 2K, 2.6k, 3k, 3.6k, 4k, 4.6k, 5k, 5.8k, 6.4k, 7k. (Should I just move them to 1k,2k,3k,4k,5k,6k,7k ??? )
*********Log # 1 ******
SAFC settings : Lo - +2% 1k-7kacross board
Hi - -10% 1k-7k
RPM Knock TIMA Fuel Inj Duty Inj Puls 02-R MAFS
2750 0 25 6.2% 2.8ms .07V 163HZ
2781 0 21 12.5% 5.6ms .03V 338HZ
2937 0 18 15.6% 6.3ms .76V 401HZ
3093 0 15 19.5% 7.6ms .78V 495HZ
3343 0 15 25.7% 9.4ms .82V 633HZ
3687 1 14 36.7% 12.ms .83V 815HZ
3968 11 9 43.7% 13.3ms .83V 959HZ
4437 10 9 50.7% 13.8ms .83V 1085HZ
4718 9 10 54.6% 14.0ms .83V 1179HZ
5093 14 8 60.9% 14.3ms .83V 1261HZ
5187 16 7 60.9% 14.0ms .83V 1273HZ
5468 15 9 64.0% 14.0ms .83V 1311HZ
5718 15 10 65.6% 13.8ms .83V 1367HZ
5875 28 12 68.7% 14.0ms .83V 1430HZ
6125 27 7 70.3% 13.8ms .83V 1436HZ
6468 26 7 72.6% 13.5ms .83V 1480HZ
6656 26 6 73.4% 13.3ms .83V 1505HZ
6718 25 6 71.0% 12.7ms .83V 1493HZ
6843 15 4 12.5% 2.3ms .85V 345HZ
****Log # 4******
Hi - -1% 1k-7k
3062 0 20 15.6% 6.1ms .80V 389HZ
3218 0 16 19.5% 7.4ms .83V 508HZ
3375 1 16 28.1% 10.2ms .85V 709HZ
3781 0 13 40.6% 13.0ms .85V 878HZ
4000 4 12 50.0% 15.1ms .85V 1110HZ
4281 3 10 54.6% 15.3ms .85V 1204HZ
4593 6 9 60.1% 15.8ms .85V 1273HZ
5062 5 9 66.4% 15.8ms .85V 1399HZ
5281 4 10 67.1% 15.3ms .85V 1430HZ
5562 5 11 71.0% 15.3ms .85V 1430HZ
5687 4 12 71.0% 15.1ms .85V 1518HZ
5875 3 13 72.6% 14.8ms .85V 1530HZ
6031 4 15 73.4% 14.5ms .85V 1587HZ
6281 3 15 75.7% 14.5ms .85V 1568HZ
6156 8 13 74.2% 14.5ms .85V 1581HZ
6375 11 12 78.9% 14.8ms .85V 1599HZ
6500 11 10 78.9% 14.5ms .85V 1599HZ
6687 10 9 78.1% 14.0ms .85V 1599HZ
I'm almost in the +% with the SAFC-II high setting that seems like a lot of fuel for 550cc on a 2g MAS and 14b? No?
Damn something got screwed up when posting, the numbers are all shifted to the left, hard to read that.
Try to get a .doc posted Monday morning.
It is a little hard to read but you have tuned out a good bit of knock. The first log shows a considerable amount of knock above 5k and your ignition timing suffers severely. On your last log knock is kept to a minimum and the timing curve is looks pretty good 9 10 11 12 13 15, then it drops off at 6k. A stock timing map shoud peak at about 15, 16 and stay there. The knock count goes up at 6k too so I would richen it up some there. I never tune by just a narrowband o2 sensor but if your o2 sensor is working properly then most people want to see between .92 and .95v at wot.
Sorry I was just trying to get a .doc setup, the copy and past didn't work that well from notepad.
Attached is log file :
Trying to figure out what happened between 6031RPM - 6281RPM - 6156RPM on second log?
Is that a miss-fire ? I have new plugs , but my plugs have some miles on them, one coil is chipped but boot covers sufficiently?
  • Wanted 6 bolt NT water pipe
    • chrisman287
