99dsmer4g63
- 908
- 686
- Sep 20, 2022
Shippensburg,
Pennsylvania
After 2 years I finally got around to finishing and starting my car. Started rough as I expected. Air fuel was off and it didn’t want to restart very well.
Figured my injectors needed to be cleaned which I still plan to do however after doing some basic checks I noticed link showed 18.3 volts. I immediately shut it down and grabbed my meter.
The battery is in the trunk and shows 14.2. The turbo timer shows 14.4. So it seems the car is running voltages as it should be but link is saying otherwise.
What I find really weird is the laptop still shows high 17’s low 18’s while just the key is in the on position and capturing with the engine off.
Figured I should mention I have the generator g terminal clipped at the 4 wire alt plug to leave the ecu floating forcing the alternator into “high” voltage mode. Or something extremely close to what I said it’s been awhile since I did it.
I found this thread
www.dsmtuners.com
where @steve mentions about checking pin 38. The meter shows battery voltage when the key is off and with key on it drops zero when the mpi relay turns on.
I can post a picture of the ecu board if wanted. Any thread I’ve found all pointed to the ecu being the culprit. Ecm tuning installed the chip about 4 years ago and “checked” the ecu at that time.
Thinking early next week I’ll be sending it out to them. Even if they tell me it’s completely fine at least I know my problem is elsewhere I suppose.
Thanks
-Daniel
I found this thread
2G - Low voltage in ECMLink but perfect at alt and batt???
So I'm struggling to figure out this issue and can't quite find a thread that describes exactly whats going on with mine. I got my new motor built and dropped in. Now on first startup it was running weird and rough(very rich 10.4) so I checked on ECMLink. In link it was showing 6.4v for the...
Thanks
-Daniel
