pottersgst
- 124
- 118
- Oct 15, 2006
franklinville,
New Jersey
ok so I drove my gsx yesterday, perfectly normal day boost is about 11-12 lbs on a t25. Parked the car for the night started today and did this for a log, sounded fine normal warm up got in drove down the road fine out of boost. went to go from stop sign hit boost and felt like I hit a wall. still spools bov sound still there just wideband hits 10 pure rich like im not getting air but out of boost car runs fine put the car in park revs normal hits boost still fine so seems only under load. no obvious boost leaks, though I will be doing BLT when done typping. like I said car ran fine parked it and next morning this crap. I did take a log in ecm link but cant call myself a tuner I have not done a lot with the system since install just got it to make car run again. only questionable thing has done in past couple weeks is occasionally will start throwing knock while cruising around 50-60 get out of the throttle get back in it usually stops and fine again. also doesn't happen everyday and my wideband still reads 14.6 while its knocking im assuming its phantom knock but I looked at sensor no goo pouring out yet but im hoping someone can look at file and see the timing jumps it makes an say yes that's ur issue, or atleast a sensor in general as that seems the more likely scenario. Its a pretty stock 95 gsx, evap deleted correctly R&d Thermal exhaust no cat, turboxs bov some piping stock side mount, aluminum intake K&N filter, plx wideband and ecmlink, and fuel pressure at idle is 42 1/2 anything else just ask profile is pretty up to date
