Limits of 190lph pump
DSMKevan
491
Mar 19, 2004
Clarkston, Michigan
I think I just made a mistake in ordering the 190 pump. I was going to go with a 255 at first but then thought of the required FPR. A 2.4 block will be installed in the future along with lots of other mods including FMIC, ic pipes, evo3 ex manifold, bigger injectors, 3 inch exhaust, ported stock turbo or bigger turbo, 3.5 in GM MAF and MAFT, and many other. Will the rewird 190 crap out with the 2.4 and a bigger turbo? Should I try to return the 190 and get the 255 instead?
I searched some, and couldnt really find a for sure answer that involved the 2.4L. I also got the pump and kit for cheap so I could possibly just sell the pump?
But does that change as the HP increases? I searched and found out that with the stock engine that the 190 will probably be able to flow enough for a 20g or even a 50 trim at 20psi. I dont think Ill ever go more than a 50 trim, so I might just keep the 90 pump. I got it for $50 brand new anyways, so if I ever want to upgrade Ill just sell it and get a 255.
thanks for the help
