limited slip and VC
WFOVR4
May 31, 2004
C/S, Colorado
What purpose does the VC serve if you have a Limited slip front and center diff? Do they make limited slip VCs?
Great info, thank you. So, if you are running a LS center and front diff couldent you run a VC elimanator? Wouldn't the LS center be doing all the work the VC did?
WFOVR4 said:
Great info, thank you. So, if you are running a LS center and front diff couldn't you run a VC eliminator?
No, the VC eliminators are designed to lock the center diff. You could get rid of the VC, though you would need something to hold the center shaft retaining ball in place.
Yes.
