Light weight wheels with large offset
Yao
Aug 27, 2004
Denver, Colorado
Hello all,
Anyone know any brand of Cheap, lightweight wheels with 32mm offset? I have done some search but couldn't find any cheap wheels with the offset I need. By cheap I mean less then $1200 for a set.
Yao said:
Hello all,
What width and diameter are you looking for?
17" wheels and the width doesn't matter as long as it's over 7"
Your title & the posting dont' correspond. You say "large offset" in the title but then ask for 32mm, which is pretty small. My Rotas are 17x7.5" with a +48mm offset, which is quite a bit "larger" in numerical terms.
So I have to ask - what requires a 32mm offset that you need? You realise that when you change the rim width, the offset changes as well - or is it that you're just looking to have a bling bling lip on your wheel? :rolleyes:
