Let's play, name those injectors!!!!
dsmoverboosted
217
Feb 26, 2006
Winnipeg,
Some guy is selling these saying that the guy he bought them off of told him there 600cc and he's just never put them in. Is there anyway to tell by looking at them?
Do these resemble any injectors any of you have seen?
Thanks Axe
As an FYI.. this is a set of Denso 660s (rusty yuck :( )
Note the P/Ns on the blue plastic 195500-0610 indicate they are 660cc
Greddy sells these same injectors but painted black, which is likely what you have if the P/N matches.
Also note that Denso 660s flow rate at 43psi base pressure can vary from 660cc/min to 720cc/min so strongly suggest you send them into FIC or CruzinPerformance for a checkup/test. FIC tested mine and found they flowed 710cc/min so had to factor that into my fuel calibrations :dsm:
