Name those connectors!!!!!!
kwAlk23
82
Sep 9, 2006
Palm Harbor, Florida
Ok, so I am in the process of an engine swap into a 90 AWD talon. I'm really hoping you guys can help me out on this one!!!
These I am pretty sure I am on the right track with, but not 100%
Pic #1 EDIT: Woops, where I drew the arrow and labeled it as fan I meant to put coolant resevoir
These next two I am just about clueless with. Which one goes to the 90 CAS? Do one of these go to the EGR valve?
Pic #2
Pic #3
Last one might be cruise control, if your car was a california car it will have the EGR connector, if not then it won't. I did note the connector for your EGR temp sensor, obviously your drive train came from a CA car.
Thanks alot guys!!!! I appreciate. See, I dropped my main harness down to give the bay a cleaner look.
The second picture is a long harness, that originally looked like it ran to the starter(It was located under the battery originally)
The third picture was originally up around the injector resistor pack right behind the throtlle body, so yes right around the cruise control.
Any more help will be greatly appreciated!!
