Left blinker not working help
george5366
126
Dec 29, 2004
Stockton, California
My left blinker doesnt work but my right one does whats wrong? checked all the bulbs perfect condition. The lights turn on it just doesnt blink. The green arrow doesnt light up either but the right one does. is it the flasher fuse? where is it located?
Did you make sure the blinker fluid level is at MAX, you might have to add some. :rolleyes:
Yeah, check the flasher. I don't know where, but I could imagine under the hood on these cars? Do you have a hayne's manual, that would tell you.
Good luck
The flasher and fuse is the same for both. It's almost certainly the bulb. Replace (or swap with right side) both front and rear left turn signal bulbs. You can't tell by just looking at them or measuring resistance. If that's not it, you may have a problem with the turn signal switch in the column.
but shouldnt the green arrow on the dash work? even though the bulbs are malfunctioning?
If replacing/swapping the left side bulbs doesn't work, suspect a faulty "Turn signal and hazard flasher unit" before suspecting the column switch. I just checked my schematics and noticed there are 4 relays inside this unit.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
