LED interior project
gabriel_dsm
73
Mar 27, 2014
bakersfield, California
okayy i have a 95 gs i want to have a red interior i know that the light of the air control thing can be changed and the ring around the key switch to but does anyone know how to do it or can send me the link to a write up i couldnt find one on the search
Yup, "it's just that easy." LED replacement bulbs will absolutely not net you the same results you'll want. I can 100% assure you that you will have both bright and dim spots in your gauges if you use LED bulbs.
Follow what Cracked put in the link. The LED strip throws an incredible amount of lumens for the small space, so it may not be 100% necessary to sand the gauge faces. I hadn't tried it without them sanded, but the intensity of the light might be enough to not need to sand the gauges and re-set the needles. The needle reset is the biggest pain.
Here's an example of a cluster that was done with LED replacement bulbs:
http://www.yotatech.com/attachments...-opinion-post-pix-if-u-have-them-cimg0199.jpg
My results:
http://www.dsmtalk.com/forums/showpost.php?p=2493594&postcount=199
While it's a video of my paddle setup, I flip the gauge lights on in the middle of the day and they light up like the 4th of July:
thats so sick! i agree i already have my gauge cluster with led replacement it does have a bit of dim spots but i like the results im just trying to get the rest of my interior red such as the AC controls and the key switch light but i dont know how! but im really going to look into doing the strip thing it looks sick
Ah, a search will net you what you are looking for. Not that I'm not willing to point you in the right direction, but I know the information is on this site as I've read it, I just can't think of what to look for.
Leds look really good. I'm thinking of trying this. My current gauges are starting to get really dim.
I did mine with red plastic behind the instrument cluster after I wet sanded off the amber color, even with the incandescent bulbs it looks amazing.
