leaning out/o2 volts drops
Jt_4g63
45
Mar 4, 2010
riverview, Florida
i just got my ecmlink v3 and i am making adjustments,~1press~ ok but some knock. ~2press~ no knock but o2 volts drops car leans out, started to use wideband for stock o2 readings.~3press~ back to stock o2 but same thing, i tried to raise from -18.4 to -10 g fuel car runs real rich up to boost but still leans out HELP!!!!
auto, stock rewired fuel pump,fic 550cc,fmic 28x6x3,on stock 14b turbo now, 16g down, ssq bov,boost controller ecmlink
Alright, slow down man and try to make it alittle less confusing as to what changes between each log, it even sounds like your mods change from log to log too? Whats a stock 14b turbo 16g down ssq bov?
:dsm:
I meant explain EACH mod in every log since it sounds like you did something differently to the car from log to log. Nobody on here can help you unless you make it more clear as to what your asking from log to log...
:dsm:
the mods r the same in all logs 14b turbo, fic 550cc, rewired stock fuel pump, 2 1/2in intercooler pipes fmic 28x6x3, boost controller, ssq bov, full 3in exhaust pipe to Apex'i N1
the only thing i changed was timing Oct tables, maf comp, i try running stock boost samething.l am about to try all stock again. what do u think
the 2nd log a changed the computer from reading stock o2 and made it read the wideband .i changed it back to stock o2 and still leaning out
