Lean On Decel
CrazyM
409
3
Jun 22, 2006
P.G., BC, Canada
Done some searching and can't find the answer.
Is it normal to run lean on decel 17.0+
On my UEGO wideband when I gear down it goes way lean.
Just wondering if this was normal? I'm thinking it is, ### the injectors deadtime is cut right down or shut off correct? But if that is so, why would a car backfire on decel? This is normally caused by running to rich..
Just a tad confused on this right now..
Ah ok, thats what I thought. I was pretty sure of this 'till I had a guy, mechanic actually telling me it was normal to run rich on decel cause the injectors would still be pumping fuel through. I'm assuming he got confused on the same note I did at first haha
Thanks tho :thumb:
my LC-1 goes 21.9 when I'm on a decel.
its perfectly normal as the other poster has said.
