leaking tranny fluid looks like from speed sensor is that possible
dylon_boosted_hx40
Sep 14, 2015
oshawa, ON, Canada
hey there new to this site I have had a dsm for couple years now I recently just bought a new one an spun a rod bearing like a month later so I swapped the motor an now im leaking tranny fluid looks like its coming out of the speedo sensor is that possible ? if not where would it be coming from its all over the speedo sensor an a little poudle right next to it an its a small leak
The speed sensor probably has an o-ring seal that can potentially leak. If the wiring harness got yanked on during the engine replacement it is possible the seal or the sensor itself could have been damaged.
yeah its gear fluid an furgot to mention that now my speedometer needle is jumpy as well don't no if that has anything to do with it either
an thanks man I cleaned it up now gunna drive it around haven't drove it since I noticed leak an hopefully that was the problem
th
thanks man gunna replace those an hopefully that fixs it cause my buddy did pull on it furgot to disconnect it from the tranny when we were pulling it like I said its a small leak but a leak is a leak u no
I can confirm after changing a speed sensor in mine, it DOES have a o-ring.
Well mine was on a 420a, but I assume the other models transmissions would be similar.
