Gsx Leaking fluid from???
grail97
Jun 19, 2008
Harlingen, Texas
stock 95 gsx automatic. was leraking auto trans fluid from bottom around tcase and was all over everything.. removed engine and replaced torque convertor seal and driver side cv axle seal put it back together and now it leaks way worse.. wtf.. only thing i can think of is the torque convertor seal isnt to spec and is were the leak is.... i dont know, what do you guys think.. i've pulled this damn engine 4 times now over the same b.s. damn leaks...
Make sure you havent over filled the transmission. Even half a quart too much and it can reak havoc on you tranny. Sometimes it will bubble out the fill tube or build so much pressure that it pushes thru the seals.
