Leaking Fluid. Where can if be from?
havok735
Jan 21, 2004
Rochester, New York
My 95 GSX is leaking fluid onto the support beam thing that sits under the engine and tranny. It isn't leaking fast, but does anyone have any ideas on what it could be before I check it out this weekend? What is in that area that could leak?
Oil leaks are very hard to pinpoint.. but I'd look forward and upward of where the residue is. If its the support that runs Front/Back under the Tranny.. I'd suspect the valve cover gasket or valve cover vent.
Thanks for the info guys. I am going to try to figure out what kind of fluid it is and then check out the ideas you brought up. Also, I am going to check the levels on everything to see if I can figure it out that way.
