leaking caps in ecu
keithrod2069
Sep 2, 2011
medford, Oregon
Need a md159965 ecu today . Called shucks, cardone wants 2 to 3 weeks to fix.
Ecu is reman with 1year warranty.$502.99 ,+ $15.48 shipping. vehicle has a cap leaking all over solder removed :hellyeah:causing bucking , misfires.
500 bucks is a ridiculous price!!!!WTF
FWIW Tom and Dave do amazing work at ECMtunning. If you ship them the ECU they normally have a quick turn around. They will check for any other trouble spots and contact you with info of any other damage. :thumb:
Directions/Instructions are here ECMTuning, Inc.
I know you say you need it now but that is not plausible unless you know someone local. You could use next day air and get your ECU back sometime early next week. Again this is just a suggestion and you will have a cleaned and serviced ECU.
As far as purchasing one, you can do that in the classifieds but again the item will not arrive until next week anyway.
Robert
I also noticed that you specify GVR4 but you have your vehicle listed as a 91 TSI AWD.:confused: Which is it? If it is in fact a GVR4 you might want to contact ECMlink, as I am not sure about that specific ecu.:coy:
yes, i will send it to them the 1991 Mitsubishi vr-4 twin turbo is my buddy car. IM IN THE MIDDLE OF A COMPLETE REBUILD WITH GODSEND, T-25 GAREET UPGRADE., Keith
So are you asking the question about the GVR4 ECU???:confused:
If so you might want to contact them as I am not sure how much they deal with those.
If it is the ECU in your 91 then you are good to go. Follow the directions in the link and send it next day with a return next day label if you are that pressed for time.
Robert
