Dhan
Supporting Member
- 3,772
- 192
- Apr 29, 2010
Denver,
Colorado
I had a question about how to wire the LC-1 and the a/f gauge that comes in the kit.
I used this guide to put everything together, ECMlink's LC-1 install.
Red Wire to the 12V Radio wire (I don't have a radio)
Blue Wire to a bolt on the chassis for ground
White Wire now goes to pin 24 on the ECU
Yellow is taped off
Brown Wire now goes into pin 4 on the ECU
Black is setup to the calibration LED/switch per the instructions
In the the ECMlink guide it says to tape off the yellow wire and use link's narrowband simulator. So that's what I did. However I can't get the LC-1's O2 sensor to calibrate (the LED just keeps blinking and gauge just blinks "7.4").
But in Snowboarder's install guide, it states to put the yellow wire to the gauge's white wire (from that link I'm using the fifth one down, for a 1g).
I'm wondering if the yellow wire being disconnected is causing my calibration troubles.
I've checked and rechecked my wiring, and everything is grounded and routed properly according to the above guides. The LC-1 kit is brand new.
Car is a '91 fwd TSi and I'm using the LC-1 sensor in the OE O2 sensor location (so no stock narrowband sensor).
EDIT: I have another question, should the white wire to 'sensor ground' (pin 24) be spliced into the existing wiring, or should the existing wiring be cut in the same way you wire the brown into pin 4?
Yellow is taped off
I'll try the cigarette lighter 12V instead. Worth a shot.
