launch control
Slightly less common is using a MSD ignition as launch control. You can set a 2 step and anti-lag with one by using your clutch switch. If I didn't have DSMLink I'd consider this since this is also an ignition upgrade.
Or a Greddy Emanage or Emanage Ultimate.
They both support that feature.
EDIT:
I can sit at 3200 with WOT and spark cut and see 10 Psi of boost !!!
