98mitsubishigst
- 1,526
- 16
- Nov 17, 2008
Pittsburgh,
Pennsylvania
Okay, i know there are threads about this somewhere, but im heading out to work and ill just check this thread out when i get home =)
1. okay, so i know the correct way is to take timing belt off and cams/cam gears and all that jazz but i was wondering if this way is fine too.. ill buy the tool and not going to be using the screw driver trick.
YouTube - Lash Adjuster Removal Tool
2. If im replacing one lifter, do i have to replace all the lifters? im using the 3gs. i was just going to replace the ticking 2 lifters.
3. I have to get all the oil out of the new lifters first then put them in correct? i don't get all the oil out then put new oil in and put them in correct?
4. after i replace the lifters with the 3g lifters, there should be lifter tic untill the lifters get oil in them right? i don't wanna crank the motor over and get scared shitless haha..
5.. UNTILL; i do this, can lifter tic hurt my car at ALL? like if i let the car sit at cold start and let the oil get to the lifters, then drive. Am i okay?
6. People around me say lifter tic can cause rod knock.. and a kid that had an eclipse around me said he had lifter tic for 3 months then got rod knock.. well its my 3rd month.. will i get this crazy rod knock ?
Thanks =) sorry for asking all these questions!
if you can number your answers!!
