2G L19 ARP Head Studs Vs Reg ARP Studs
If you can swing it, they are worth having, the clamping force difference is enough to go for it, you might only want 500 hp but the cylinder pressures are much higher if you get detonation than they are during a clean pull, the better studs can save a head gasket or two.
