ECMlink knock log?
There is a lot going on with this log. Your car is stuck in open loop, Your battery voltage is way to high at the start, your air flow per rev is to high, your map sensor is stuck at 39.4psi. I do not see a wideband logged? What fuel is car on? i see you have stock timing table and looks like stock SD table?
