help with log/knock
r6_philly
May 20, 2005
Upper Darby, Pennsylvania
so I finally got a logger in the car. Played around with it and SAFC and got lots of knock. Fixed the lo-th with SAFC and so did the hi-th. Now last run I still get knock at partial throttle. low throttle (<30%) and high (>65%) it runs great.
Here is the logs for partial throttle. Can I just changed the low-hi setting on the SAFC and make it either hi or low? (50/50) instead of having the intermediate step? The ECU apparently isn't dumpping in more fuel.
9/23/05-23:01:05 - GFMS
Time RPM Knock Timing O2 TPS O2 Trim Inj D/C
01:37.5 1375 0 24 0.59 25 105 5.29
01:37.7 1406 0 14 0.75 33 97 7.51
01:37.9 1406 0 13 0.76 38 90 7.51
01:38.1 1438 0 13 0.71 40 82 7.68
01:38.3 1469 7 11 0.65 47 100 9.73
01:38.5 1531 14 8 0.8 52 100 10.79
01:38.7 1594 13 7 0.84 56 100 11.58
01:38.9 1625 13 7 0.86 57 100 12.15
01:39.1 1688 13 6 0.86 57 100 12.62
01:39.3 1688 12 7 0.88 58 100 12.98
01:39.5 1781 12 7 0.88 58 100 13.7
01:39.7 1813 12 7 0.88 58 100 14.34
01:39.9 1875 11 7 0.9 59 100 14.83
01:40.1 1906 11 6 0.9 59 100 15.07
01:40.3 1969 11 6 0.9 59 100 15.98
01:40.5 2031 10 6 0.9 60 100 16.48
01:40.7 2063 10 6 0.9 60 100 16.74
01:40.9 2125 9 8 0.9 60 100 17.25
01:41.1 2188 9 8 0.9 60 100 17.76
01:41.3 2250 9 8 0.92 60 100 18.75
01:41.6 2281 8 8 0.92 60 100 19.01
01:41.8 2344 8 8 0.92 61 100 20.53
01:42.0 2406 8 8 0.92 61 100 21.59
01:42.2 2438 7 7 0.92 61 100 22.92
01:42.4 2500 8 7 0.92 59 100 24.56
01:42.6 2563 8 8 0.92 53 100 23.56
01:42.8 2656 7 8 0.92 44 100 24.97
01:43.1 2688 7 17 0.92 13 89 14.36
01:43.3 2781 3 36 0.94 13 76 3.57
01:43.5 3000 0 39 0.9 13 62 3.2
01:43.7 3000 0 39 0.18 13 63 3.2
01:43.9 2844 0 39 0.04 13 100 0
01:44.1 2625 0 25 0.02 13 100 0
01:44.3 2313 0 25 0 13 100 0
also how much Inj. D/C can you push? on the WOT runs I get about 89% with the stock injectors, stock pump and a 16g. I am only running 11 psi's for now. If I push it up to 95% or more would I run the risk of anything? What happens at 100%?
the lo/mid/hi trims are 132/105/100
TIA
also 2 more questions:
since the low trim is so high, is it possible that the O2 is on the way out?
also the 5th run the mid trim has been increased from 100 to 105, and low from 138 to 132 (after I up the lo-th correction on SAFC). Should I just keep driivng a bit longer and wait for the ECU to learn my car further and maybe knock will be down/fuel trim will go up?
I am missing something here...... :confused:
If it wasn't a WOT run, why are you trying to tune making a 1/2 throttle pull WTF ?
Tune your trims at idle. 1k, 2k, 3k and transfer these settings across the rest of your low throttle Ne Points.
According to your O2's when knock develops it starts getting rich too, even though I don't trust a narrow band worth a damn.
But try this:
Add fuel at about 1500, possibly 10% and trim out til the KS picks up.
If that doesn't work, you may have to pull a few degrees out of base timing.
