ECMlink knock issues
Hickory-NC-2Ggsx
Supporting VIP
312
137
Dec 27, 2018
Lincolnton, North Carolina
hey all! so I have been haveing a knock issue i have the timing sliders all at zero, and stock 2g timing tables. But I'm trying to get my afr all sorted out and I'm just concerned about the knock I'm getting, could it be that the intake temps are to high? or do I need to richen it up? the setup is ported big16g,255 fuel pump, fmic, fic 650 injectors,3" turbo back,ir boost controller, innovate wideband, arp headstuds, new oem knock sensor as well. oh and gm3bar doesnt work i believe its a cheap ebay 3 bar sensor. but thanks for any tips! oh and its been very hot down here in NC so ive been fighting high temps every where.
As vegas mentioned, nothing to worry about. You'll see that kind of knock occasionally here and there even after it's dialed in. It's a little rich there too so it might go away once you achieve target afr.
