kinda confused and need help.
RocCitySlayer
792
7
Nov 20, 2011
Rochester, New York
I just bought a felpro turbo to manifold stainless steel gasket Set and it came with 2 of the Gaskets Gaskets that go on the bottom of the manifold. My question is. Do I use both. Gaskets or just one? Help needed asap thanks.
You use just one on the turbo to manifold flange. There are 2 because there are different options for turbo's. That kit is made to work on a 90-99. The tdo5h and t25 use the same gasket with the bigger hole and the tdo4 uses the smaller hole offset to one side.
Thanks for the info bro. Appreciate it
